Sven the Sexman
I have heads and and ST5 in my basement, along with a double roller. Head studs on the way then the 600+ wHP fun begins.
Git-R-Dun
GTP rods are stronger than NA rods, gtp crank is better as well, we used gtp bottom end and put diamond racing dished pistons with a t66 up top on my buddies impala.
the gtp rods are stronger for sure, it was an NA block.
Also for reference we had done a quick fun run and my Z28 was a mid 11 second 1/4 daily driver and the impala put buss lengths on me and he had subs/box/tools/full interior... Since the car never ran at the track our best estimate is it was at least a mid 10 second car.
JUST NO! like said earlier, dont touch the bottom end. or you'll just waste it. thats called a 200 mile engine.
your also gonna want a way to tune it when done. it should run on a gtp stock pcm, but a tune will help it out.
Question: What the hell? Why do people have issues building a short block? I don't understand. I have built everything from Briggs and Stratton and other small engines, 2 cylinder 2 stroke Rotax, Lycoming I/O 360, LS1's, several Chevy 350/383'sQuad 4, Ford 3.8 SC, 3.1/3.4's and never had any issues with an engine coming apart. Not to say everything has gone perfectly, but come on a 3.8 Buick? What's the deal? Not trying to be a smart ass or anything just seems really odd that messing with a bottom end would be a 200 mile engine unless you do like my dad did on a VW engine and torqued the mains and rods without using a torque wrench and seized the engine after about 5 miles that was in the early 70's when he was becoming an aircraft mechanic in the Army and thought it's just a car engine it doesn't need to be held to the standards that aircraft do.
Jeff
Jeff
GTP crank is the exact same crank as the NA crank. Rods are made of same materials.
Sorry I realized I did not specify, we used the crank and rods from a gen 3 gtp. Although I think there were some differences between 2004 to 2005. I apologize for that I guess that's what I get for sitting here at work with 4 tasks to do and trying to read stuff here, I am getting too old for this multi tasking crap.
