starting a top swap on a 2000 gp l36 still collecting parts
so i picked up a fuel pump/sender/bucket assembly from the local junkyard today. is was from a 2000 gtp. how do i tell if i picked up/identify the unit i bought as a venturi pump or not?
also scored a gen v huffer today too!
If it's venturi, you will see a little black hose on top of the pump.
Also, if the car had a steel tank, it's venturi. If plastic, non venturi.
sweet! yes the car had a steel tank and yes i see the little black hose on top of the pump inside the canister!
if that's the case, this pump will go into the car tonight!
oh another question- what about this 2 speed pump business- i guess i need to get this pump to always operate in high speed mode for my non gtp wired car with top swap?
