Ask your water methanol injection questions here.
  • Thread starter Thread starter DevilsOwn
  • Start date Start date
they are all 1/8 NPT i believe. also, why you takin my idea with modding the blower? do it in your TB right after the MAF and before the throttle blade. that would be better really, but im just looking for something unique and im stubborn.
lots of cheap places to buy methanol. Should have no problem finding some for 3.00 a gallon or so if you look. Call around to chemical supply places in your phone book. cheap windshield washer fluid
All nozzles we sell are 1/8npt so you can do that and put a pipe plug to seal it.
Cool thanks. If you know of any places online feel free to share.
Oh, sorry for skiping yours question. Not sure why you are seeing yours being off. Ken got the numbers directly from a grandprix 2 bar map sensor. Now there are afew that have been used thru the years and can vary some but should not be off much. If you switch your ls1m to show map sensor votage. 2.8v should be 2psi, maybe ls1m is off. I will yank mine out and look to see whos math is off.
I would look for something local vers shipping it or ship it from the nearest town.
This is the stuff I use.....mix to your hearts content.
Truck stops are wonderful places this time of year to pick this up.
How much is that stuff brian. Can't get any of that stuff around here :(
Hey Reptile, that stuff you posted for Meth, is that stuff 100%? Anything else in it? Just curious.
Also, can some one help me out? To mix my own with water, what kinda water should I specifically use? Distilled? Mineral water? Tap water?
distilled is best. if youre lazy i would use tap water, but it has so much crap in it that might do something that i wouldnt do it forever.
Distilled water is the best to use....when in doubt, buy the bottled stuff at wal mart in the gallon jugs...or if you have a water purification system...like say from the fridge, that will work too. PUR pitchers are great as well, and measuring is easy.
Shawn, that stuff is 100% Methanol with a blue dye like washer fluid, but you can also get it in clear that's by the gallon. It's a little high, at $2 a bottle, but it's readily available to me at my work, so I go ahead and use it.
Cool, distilled it is! That all I use for my IC fluid mixtures anyway. I like it much better.
Thanks for the info Brain. Now if I can only find 100% meth locally and priced reasonably.....
Since Devilsown is local and Chance was at the shop Saturday, I picked up some Devils Brew for my setup, I figured what the hell...
Ok, so fellow ALKY users. Any kinda special PCM tuning you guys are doing to optimize you're setups? I know I need to lean out my setup during WOT. For now I got that covered with my ICCU.
What AFR should I shoot for via wideband? Should I add timing, boost, or both? I have a brand new 2.9" non-slip DUB i've had for a couple years and have never used. I wondering if I can use that? I donno which is better, but i'd like to add boost I think. I cannot drop any lower than a 2.8" though because my snout isn't cleaarenced.
Not sure exactly where I need to start out with my new toy....
I like shooting for 12.0-12.2, it seems to give the best gains....and max timing at 25*.
Never could get it to do any better with any higher than that.
man i dunno how u guys are able to run 12.0-12.2AFR cause i cant seem to run even 11.0-11.3 w/o getting KR on decent timing:th_sick2:. i dunno if my plx wb is fubar'd or not but i can only run kr-free with 20* with a 10.0-10.3AFR:th_angry2:
What is you're injector duty % at?
IDC IIRC is ranging from 76% and goes up to ~86-87% top of the gear, except in first gear as i've seen it go as high as 96% b4 shifting into 2nd gear.
Wow, 12.0-12.2, thats pretty lean ain't it? 25 degrees timing eh? Wow, I couldn't imagine running that much timing, interesting. Guess I have a ways to go with my setup.
What kinda boost were you running without Alky and with? I'm sure you upped the boost a little, didn't ya?
