grandprixfamily
Ok, now that I have your attention.
A bunch of stuff im not using or not going to use. All items located in Reno, NV. All prices are PLUS shipping unless otherwise noted. Package deals welcomed, trades considered, sexual favors always welcomed.
Ok, here we go. Pictures as of todays posting, all current, will clear items out once sold.
Link to view all pictures, ill add pics as they are requested if more detail is needed.
http://s51.photobucket.com/user/grandprixfamily/slideshow/For Sale
the whole lot:
20th anniv exhaust tips - 75
nearly new take off GTP throttle body, comes with new IAC valve - 50
59 actual miles cluster, take from an 02 - 50
ZZP fan override switch, track fans, hi-lo fan switch - 50
Old School ZZP/Easyperformence ICCU, (adjust timing, etc on the fly from in the car) - SOLD
Flowmatched 42.5/45 inchectors. see pics, plastic in ends is altered on 3, good on 3 (one bank got a bit hotter) - 75
Walbro 255 in tank pump, fits in OEM housing - SOLD
Walbro 255 in line pump (they worked great as a set on 20+psi turbo car) - 75
Northstar TB Cable bracket, for N* conversions - SOLD
Grilles, painted black by paint shop, decided not to use. - SOLD
MSD coils, the better revision, actually for GTP's, 3 used cols - SOLD
1 New MSD coil - SOLD
Custom fuse box cover, machined one off, all pieces - 30
Custom one off flame pedal set, bolts on, drill holes in OEM pedals - 50
custom one off flame grilles, fit perfectly in bumper. stainless steel, a bit dirty in this pic, a couple sets brand new available too. - 100 per set
Ignition control module - SOLD
performance shift knob - SOLD
Oil fill (stock), and custom oil fill adapter for external PCV system, turbo cars, etc - PCV (custom one) ported - SOLD
MSD 8.5mm wires, one is a bit burnt fron touching headers, makes good spares set - SOLD
Trans dipstick tube, bent to clear turbo car piping, new mount welded on, also works with headers - 40
ZZP cross braces, one has been altered (ground on edges of mounting tab) can be mounted upside down to clear custom hoods - SOLD
Taylor race wires, full set premade with extra parts - 100
Thrasher air box, heat wrapped, with MSP Polycarbonate PCM Tray
http://www.3800performance.com/pcm_tray_install/pcm_tray_install.htm
^^ PCM tray install instructions
http://www.pfyc.com/supportfiles/tepcak.pdf
^^ PDF with instructions on install and all the old data
PCM Tray 60+ shipping, thrasher airbox 150 + shiping
Wheel adapters, converts 5x4.5 aka 5x114.3 to our 5x115. custom made, held up to turbo track passes on drag radials. very nice pieces. - 200
Stock stereos, 1 EQ model left with a few bad bulbs, 1 non eq model in "parts" condition, and one chevy truck/corvette/etc model everything works like new. - varies, 20 for parts model, 30 for eq model needing work, 60 for nice chevy model
ok, shoot me some offers, i got this far and didnt price it all, not really sure what stuff is worth these days.
NEW ITEMS ADDED!!!!!!!!
not pictured but also for sale, K&N air charger kit, complete, minus filter. Heat shield, pcm tray/mount, tubing, etc.
KN part # 57-3045 200 Shipped
http://www.summitracing.com/parts/knn-57-3045/overview/year/2003/make/pontiac/model/grand-prix
New items added:
Full aluminum brake package
F body complete brake kit, brand new ceramic pads, junkyard calipers and brackets, bushings for the caliper bolts (no drill tap method, full bolt on), rebuild kit for brake calipers. Rebuild seals, bolt on and go. Just add rotors (25 each from any parts house)
Grand am rear calipers. Full aluminum, bolt into your existing brackets on a GP. uses existing pads and hardware. Comes with extra hardware.
225 shipped. Can include G2 white caliper epoxy paint kit, or duplicolor red caliper paint it as well.
the whole lot:
New items added:
