Macksauce
Was out last nite on a run and i notice that my amps where flicking, so i pulled over to look at them and behold my 0 gauge ground wire was half way out the distributon block ....so like a fool i go and grab it to pull it out(didnt disconnect the battery) and it sparks up on its way out inside the block.....so then i disconnect the battery, put the ground back it, battery back on....goto start the car...nothing but clicks .....battery reads 12volts .....lights and everything else comes on just no action from the starter.....my check engine light as already been on due to a huge vacuum leak in my intake gasket in the back side i been waiting to get fixed......so wen im turning the key the engine light flashes now...i turn and hold the key and the engine flashes until i let off the turn .....as for the starter wires ...i burned up the fusible link a year ago and replaced it with a audio fuse ...got under there checked it was blown some what(still unsure cause it didnt pop in the middle, it was dark out, but i shaked it and it was making noise) i replaced it with the one for my sound system......i check almost all the fuses only one that was blown was the O2 ssr fuse
so im at i turn the key, and doesnt crank at all, just clicks wat sounds like the pcm....then the starter a lil ....then 3 or more clicks are in the fuse box in that order.......im going out this morning to try again ...but im totally lost with this one....help!!!!! plz:th_depressed::th_depressed::th_depressed:
