MrPoopyButthole
#Billsnamechangessuck
I moved all the posts out of the How-To for the CTS-V since this is a totally different topic at hand.
I took the existing 5x120 bolt pattern on the rotors and just slotted them down to 5x115 no need to drill anything on the hubs and I also increased the bore size in the new rotors to match the stock hub. no need to touch the Grand Prix hubsOk. That would have been nice. When u drilled the CTS v rotor hat to fit your set up I saw it looks like you just over drilled existing holes right? I know I would not be able to do that on the wheel bearings but could I drill the 5x120 pattern in the middle of the existing 5x115 holes or would that compromise the structural integrity of that plate?
Lemme know how that goes turbo400. As far as needing the stopping power I know it's overkill. That being said I am still trying to find anybody that makes or is going to be making carbon ceramic rotors for the cts-v calipers as they are a lot easier to come by than the corvette or z28 calipers. I am still not 100% convinced that the Vette wheel hubs don't fit on the grand prix front spindle. Finding one for the rear (4 bolt hub) is going to be a different story. Coolone. As far as needing the stopping power I will be needing to do a lot more work but I plan on either going with a twin charged setup but i don't know if this is even going to produce the power I want. Anybody have actual whp numbers for twin charged gps? The other option I am looking at is either modifying an lt1 5.7 or swapping in the 5.3 from gxp and putting a whipple on it. Just sucks cause I already have a little over 10k in my 3.8 motor... anybody wanna buy it? Lol. Last dyno numbers were 265 whp. Can't remember torque. Either way it's no where close to my 500 goal. Also have no idea what to do about a trans. Lots of people talking about dog boxes. Transmissions have just never been my thing. I can do pretty much everything else but not gonna lie transmissions intimidate me.
so wait a minute f body calipers on 15 inch rims? hmmm caged car has some baby grand am brakes on it now and i have 15 inch slicks. wonder how much of an improvement that would be?
oh for ****s sake i just told you they are the same 3 bolt pattern, the corvette rear hub bearings with the axle splines will bolt into our front knuckles, and if your looking for the 5x4.75 lug pattern instead of the 5 x 4.5 then you use the 4 bolt front wheel bearings from the F bodies (which would blt into your rear knuckle.
ive driven a full boogie compG build with gxp front and rear brakes and its stupid easy to lock em up and end up with the abs on and not stopping nearly as fast as a good threshold braking technique....kinda touchy without the gxp pedal/pushrod pivot point on the brake pedal arm.
i dont see why youd want the headache of that large of brakes aside from bragging rights
the Riv actually wrecked because the front brakes did lockup...even with 255 MT dr's (abs deleted)....not good at nearly 100mph
huge is awesome but not always better
this gets more dumb each post.
All you're going to do is lock em up and slide all over. You're also going to need tires sticky enough to transfer the braking force to the road. But hey if you threw 10k at your motor for only 260ish hp....then sure throw another 15k on brakes.
