    TIPS:
Offboard Tuning Rigs (2)
LOL Josh.
Power supplies are often free from old pc's. Only things to pay for are connectors, time and some tape/solder/knowledge. Connectors ran me more than I hoped. Darn old grouchy guy at the JY.
Yep. I was there. Maybe we should bring a HAPPY meal for those old bastards next time lol.
Technically, I believe those to be output, since nothing else is happening...I'd bet it's backfeeding the ground you need and working fine.
0.0 ohms/continuity to all pcm ground pins on all 3 connectors.
think of it this way bill. tiny ground loop disparities can drastically affect the signal of a ohm/5 volt reff system.... to avoid this the PCM uses redundant grounding to a huge extent.
remember they want to make sure that your car last to 100,000 miles before it falls apart and rust starts kicking you in the nuts
Still got 1 available? Ill buy asap
will it work on 05+impala(series II engine)? if so how many canadian dollars do I have to pay + shipping?
I live st thomas ontario n5r 2b1 is postal code
would like this to change my gear ratio and fan settings
Guys.. I don't have any left at the moment. Pretty sure I have a power supply or two. I'd need more connectors. Lemme chat with Dogger and see what he has .. maybe we can make this happen for you two.
ive got 4 power supply's, maybe 5 that work, i need to test em. 4 have the power cord. all i need are pcm and obd2 plugs.
That'd be awesome bill, seems like a cheaper option the mailing my pcm back and forth to overkill for the tiny adjustments that I need.
PM me or reply to this thread if you make some or have a update on whats going on, Ill keep an eye on this thread.
this isn't a tuner. its a just a off board interface for a pcm thats out of a car then hooked up to a tuner like DHP, or HP tuners.
