Just finished replacing the LIM & UIM gaskets on my 06 grand prix, and when its running there is a high pitch squealing whining noise that sounds like a pulley or a vacuum leak. its not a pulley though. sounds to be coming from the right side of engine (#2,4&6). the car runs and drives, but it idles around 830-850 rpms. seems high to me. whats normal idle in park?would the fuel injectors make a vacuum leak noise if not seated all the way? what should I check that might be causing this? all hoses are attached, and I cleaned throttle body. I will try to get a vid for you guys
