E cig, cause cigarettes are for losers
i will sell you my setup of exactly what ace just said. i don't use it. you might want to replace the battery (the adjustable voltage ecig mod, an e-go twist 1300mAh [neon green]). i have a case and everything that i all got a while back. i'll clean it for you before i ship it, too.
i assume you wouldn't want the juices, though. they're all 0% nicotine.
You could do what I did grab a kanger protank3 and an adjustable voltage. Ecig mod from eBay and your good to go. There's YouTube videos on how to build coils for the kanger tanks and I liked my set up.
ya thats about the cheapest route, any cheaper would just be a ego battery with a mini protank on top. That would be the "smallest" option imo.
Just go get any mechanical mod or the Aspire cf mod(made for the atlantis tanks) and 18650 batteries. Run the aspire atlantis, closest to a dripper you can get while it has a tank. The sub ohm atlantis can also use any weight of juice giving you far more selection.
Sent from my SM-N900V using Tapatalk
going from cigs to a mech mod is a huge jump, specially when your forced to make your own coils, measure the resistance AND learn how to properly put the wick in without hot spots.
I bought a Kanger EMOW Mega starter kit... Everything I saw online gave it rave reviews so I'm hoping it'll work out as planned. It should be here today actually.
So far so good. The Kanger is trying to replace cigs and is doing well. I haven't had a real cig since I got this thing. And for Bio, I may still be interested in your setup. I'll send you a PM.
what kind of juice you get, %?
The smoker in me made me get 24% to match cigarettes. I plan on stepping down gradually until I'm left with the mechanical fixation and not the chemical addiction. I got 4 flavors so far: orange cremecicle, blueberry, blueberry pomegranate, and a citrus blend. The only one I've tried so far is the orange cremecicle though. As far as brand, I just got the in house brand from the place I ordered my kit through: vaporhq.com. I highly recommend them as they were inexpensive and very prompt with shipping and even sent me a free bottle of juice.
It isn't just a mech mod. It just uses the mech mod for a battery holder. The Aspire Atlantis is a tank with .5ohm coil. Look it up, it does not need building. Prime the coil, install, fill, let sit couple min to soak in, now it's ready to use. I have had all of the kanger line except the new sub ohm tank. The Atlantis works way better than those, and I use a dripper on the daily.
