BrandonHall10
Solving problems
Total tuning noob here. Drop some knowledge on me, please. HPtuners for reference.
Recently installed some #42 injectors and filled up with E85. Stock tune. LTFT's are consistently high. ≈6 at start up. ≈10 idling, at or past 16 cruising. Never negative. Never below 6.
I'm thinking I should adjust something (not sure what) to bring them down. Trying to be positive and negative by the same amount. Like, try to hit the center of that moving number. Assuming I'm right so far(?), I read that this can be done 2 different ways:
1.) Adjusting the IFR. I'm thinking if I multiply the IFR by 0.95, that should get me close?
OR...
2.) Adjusting the cylinder gain. Maybe start at 1.02?
These numbers are shot from the hip. They could be adjusted repeatedly until I felt comfortable with the results. Just want to know what would be the better, or proper process.
Again, maybe I'm wrong, but shouldn't I have my stock trims centered around zero (not be consistently positive) before I do any other tuning? All basic maintenance is up to date. New plugs, wires, fuel filter, and cleaned TB and IAC. No vac leaks.
Thoughts?
OR...
Thoughts?
