Ford Probe Heater Core??
ILoveAudi
Never Be A Tim.
I've heard from multiple sources that you can use a ford probe heater core as the intercooler core, which I know is true. I just want to know which one is right as I have gotten two different results in measurements on rockauto. Also, will they hold up?
Edit: Basically, one is 1-5/8" thick and the other is 2" thick. Since it's a 2 inch core, I realize the 2" thick core would make sense, but the length and width are all different too.
Millennia one seems like its an inch shorter than a probe one. But for some reason rock auto shows a millennia one is 126 bucks where a probe one is 33. Maybe you mean mazda mx6...which was the mazda version of the probe. They use the same heater core.
nope
had to recore a bolt together crappily sealed zzp stg2 ic....zzp sent me the core with the part number that crosses over only to the mazda millenia minivan. the second core i did i saved a ton by buying it from advanced auto parts with a coupon code.
for some reason i recall it was only the earlier non bolt together cores that were the probe core
you can see how ****ty the zzp rtv job was on the core lol
iirc we had 4 vac leaks total, 3 external (you can see two clearly at the snout side), one to crankcase.
Bingo.. The Ford Probe number is on that core in your picture James.
Now.. do you happen to know what the core that WBS used for a while came from? Because.. I loved how it hung down in the intake and gave as much as it could.
