Delilah....dyno rackar
This has been a very good weekend. Solved my major oil leak. Fixed the engine running hot problem. And so far I think I fixed my electrical problem.
So this misfire looks like it's gonna be annoying to solve. Spark plugs look fine. Even though I think I cracked one during removal.
Originally it came up P0307 cyclinder 7 misfire then turned into P0300 multiple random misfire and the cyclinder 7 one went away.
Here's 7 with a new plug.
Less than 15k miles on this set of plugs.
Strangest part of all....I drove it to the gym. Worked out. Was on my way back and bam it started. Misfire constantly. Could feel it very noticeable. Drive to parking lot and parked.
I know what happed. One of the stupid DoD lifters collapsed. Here's some pics.
In the below picture the valve was full of fuel.
If u swap lifters u have to completely remove all DoD components including cam
Yup definitely a lifter. Wonder which one is bad Lmfao.
That DOD oil build up though.
Started cleaning the pistons off.
One out of 8 completely clean.
And the way it sits for tonight.
Thin coat of oil on each cyclinder and piston to keep it from rusting.
Damn cleaning this stuff is a pain.
So how much were the new dod lifters?
And use this if you have a die grinder or drill that use these to clean gasket material off and carbon. They wont eat the aluminum away or harm it if you are smart.
3m Roloc bristle discs.
**** I was gonna replace all lifters. But each DOD lifter was 55 bucks. So just replacing the one for now.
