What 3 guages are most important to have?
Hardonyomom
Okay, so i just bought a 3 pod pillar and i need to pick some gauges to go in there.
What would be the 3 best you would pick?
I was thinking a wideband, an aeroforce , and a fuel pressure?
2 aeroforce, and wideband?
aeroforce, boost , and wideband?
Which ones are most important?
you can get an aeroforce wideband to work in conjunction with the aeroforce gauge. I'm not sure what to get for the other 2 holes, I just run 3 aeroforce's
Volt, Boost, Oil
No need to know fueling cause once tuned it's set anyways... KR scan is always good (aeroforce) but once tuned shouldn't be a problem unless something broke or maybe bad gas, lol.
But volt, boost and oil can tell me something else is happening. And yeah, I'd probably hear it before I see it if oil pressure goes, but wth... Lol, that's my $.02
1) aeroforce
2) wideband
3) gauge of your choice.
Personally I just stick with a hud pod and just run the first two
What year is your car, and how do you have your gauges setup?
I think I'll be replacing my middle Aeroforce with a vac/boost gauge too.
my car is a 2001 Grand Prix GTP. I have the aeroforce triple gauge setup with a pillar pod from zzp. I dont have the aeroforce wideband setup yet, but I am considering it as a next mod.
oil pressure is the most important gauge you can have in your car and i didn't see it listed in this thread yet. shame on you people.
a wideband is nice, but it's really only needed when you're tuning the car. after that it becomes a useless flashy light show gauge.
You have all three running at the same time with no problems? How many parameters/refresh rate?
Right now I have a triple installed, but only have 2 running. One boost/KR at fastest speed, the other cycles IAT/Coolant/Trans Temp at slowest refresh. Can't seem to get three to run reliably. If I replace one with a boost/vac then I can install my Aeroforce Oil Pressure kit on the fast refresh one.
Here's what I have.
In my 3-gauge pillar pod:
- Volts
- Boost
- Oil Pressure
HUD Pod:
- Aeroforce
- Wideband
I'd definitely say go with an Aeroforce, Wideband, and Oil Pressure.
