chicagochuck
:th_frowning::th_frowning: 01 grandprix 164,000 miles. Timeline below
The whole upper intake cracked and caught on fire behind the pcv valve, which also shoot off in the air. The sound was loud. I am glad no one was standing there. I put the fire out by dumping snow on it.
Jan 6, it started up fine and I let it run. when I came out the house the oil light was on but went off. I added less than a half of a quart of oil..it was not really low at all.
Jan 7 it ran fine the rest of the day
The next day I drove it to and from work and the gym fine. Keep in mind its freezing here in Chicago I mean 0 degrees. With wind chills in the negative
Thurs Jan 8 it would not start it had that dead battery type sound so I left it. I threw the charger on it for a few hours but nothing changed. I figured the battery was garbage its 7 yrs old... I pulled out a yellow top optima I had charged it up and put it in the car. Still sounded similar to the old battery very weak. All the accessories worked fine. The battery was only staying at about 11 volts so I decided to jump start it. When it was being jump started I tried to crank it and that's when the above happened . I have heard of similar things but never experienced them myself. I am starting to think the engine was the culprit the whole time. Not sure if it was something I could have done differently or maybe I flooded the engine...
ALL in all I'm not getting it fixed I will get something else
