    TIPS:
KYGTP Belt Wrap Kits
Status
Not open for further replies.
jdredd
I was able to get some of the belt wrap kits that KYGTP made years ago. He had a box collecting dust and
talked him into letting me sell em off for him. I am making basically nothing on these (if anything, loosing $$)
and just wanted to get them out there.
I have FB post with all the details on price and multiple pictures.
https://www.facebook.com/groups/Wbo...9840/?comment_id=629141783864506&notif_t=like
There are basically 8 bars left.
Two of them are complete ready to use kits. While rest need pulley (from advanced auto) and 5 of them need to make
your own support strap.
So if want one hit me up here, or on FB (Steven Chesser) and I can get it out to ya :cool:
Ships out of ERLANGER, KY via FLATRATE USPS shipping box.
Mind posting the pricing here for those of us that don't have a bookface to log into to see.
This is copy/paste from FB .. fixed up a little.
"Belt wrap kits. Last of the last here.
Flat rate shipping to the states. $13 via USPS.
Designed for use on GENV Blower. (Except for one)
Designed for use with full size (2.25" ) style intercooler.
Pulley of choice to use with this, works well for the 8 rib setup.
Suppose to work up to 3.25" blower pulley, but not 100% confirmed.
It will be a super tight fit at that size. But told should work.
Have to have Fuel logs setup. Stock setup makes for a fitment issue. Unless modified stock fuel rails to clear.
As can tell from pictures, its a tight fit, so big blower pulley wont work out to well, unless you go to smaller wrap pulley.
Included are some pics of part numbers of bolt/washers used for the pulley setup.
Depending on what you order, you will have to source your own parts.
Pulley used is part # 89016, can be bought about anywhere.
Strap will need trimmed and 2nd hole drilled to fit your setup. As there are different Alternator setups and different IC heights to deal with.
DOWN TO ONLY INCOMPLETE KITS!
***** THESE HAVE ALL SOLD OUT *******
(Prices went up a few $ since last update as I went out and bought parts to complete these out as best as possible)
For anyone who buys a kit with NO strap. It is not recommended to skip this part. Required to use this properly. This helps with the flex/force that will be put onto the bar itself. It is just a simple 1/8th inch aluminum with a twist in it. The twist makes for the transition needed for the bolts PLUS makes it much more rigged.
PAYPAL Only. Send as friend or family.
PM Me directly. First come first serve. Once gone, thread will be deleted, otherwise ill never stop hearing about these I will give you a paypal address. Won't be holding onto these.
No warranty/refund type deal. DIY type setup. Use at your own risk.
I looked over his photo bucket. Very interesting grand prix mods. If anyone has the time you should check it out.
Djudge1970
I had one that i bought a long time ago and i was super happy with it only difference in mine was i swapped it to a smooth flow pulley
Sold one, one pending payment.
I asked KYGTP if he can make five more straps to complete the rest out as much as possible.
He said he can make some possibly by the end of the week if you guys feel like waiting. And i'll update
pricing and availability then. Save you the head ache of doing it.
If dying to get one, and can make your own strap, I'll go ahead and ship it then as is.
So it doesn't look like this will work with the CS144 alternator bracket (1997) GPs, right? They don't have the bolt hole for the support strap....right?
Works with 97s. Actually the first car to get one was a 97 (the very first pic at the top of the thread)
97/98 have the same setup, while 99+ have a different alternator setup.
But the strap is cut long enough to reach both. (thus why it needs possibly trimmed)
If you have something totally different, then may need to come up with your own strap setup.
BTW Some links of installs
http://www.clubgp.com/newforum/tm.asp?m=4570797 (original sale thread from 2008)
http://www.clubgp.com/newforum/tm.asp?m=4968633 (install without an IC)
I had one of these back in my blower days. Very nice piece. Worked well for reducing slip on 2.6-3.0" pulleys.
Status
