largest l67 intercooler
fbm
Whats the largest l67 intercooler i can fit under a 2001 gtp i have a ssic with a 3/4 spacer if i remove the ssic can i fit a zzp core with the 3/4 phenolic spacer and would a gen v fit in the future
if i jack up my 97 gtp i guess i could fit a 25" tall stack of intercooler cores under it
your limited at about 2.25" without weaseling with a buncha mounts and cradle spacers. so a full size IC and maybe a 1/4" spacer (im assuming you have a 3/4" phenolic)
no difference in the stack eight of a gen3 vs gen5
isn't the turn down really only needed if your running a N* TB? thats pretty much the only pics ive seen of them being used.
I ran the zzp 2.25" IC, GENV + adapter + N*.. no turn down. With my GTX hood. Fit fine with no spacers.
Made for the 04+ guys that run IC since our throttle bodies are taller and once you throw a IC in there the TB tends to hit. Previous gen can just get a adapter and turn the tb upside down to make room.
I'm running my 2.25" intercooler. I've bolted up L67 and N* under a 2002 and 2003 bonneville hood.
It's a tight fit! Not sure I've heard of anyone running thicker than 2.25 without doing cradle spacers, notching the hood or both on any vehicle.
I found your intercooler. It's not very descriptive.
Its not descriptive at all but i talked to the seller and by the pics of the engine its a zzp wbody store i/c i wanted to try and keep the phenolic spacer but its not worth the hassle i dont really want to deal with the pcv system i have been looking for a clean setup and install i might just sell the ssic, spacer, and full size and get the hybrid by the way the same seller has other 3800 performance parts
