timothylockhart
Hello all, I am a frustrated owner of a 2001 Grand prix se 3.1L it has 150k on it
recently I have replaced all the following parts as they were bad.
Front wheel bearings
Control arms
Ball joints
Tie rods
Sway bar links
sway bar is new on it
Front end alignment
tires balanced
New tires
The car still runs like absolute ****.
I did notice that the EGR valve is not proper and has an extra hose that is plugged with a screw from the previous owner.
The car had an AWFUL shake at 45+ mph where it would shake the steering wheel and my jaw while driving.
Took it into to get rebalanced and it drives smoother but still has small shakes
My camber was off and they needed to install a camber kit for my front end alignment.
Car's transmission was slipping in the summer but has stopped in the winter I assume it is worn out and the fluid is thicker in the winter making it not slip.
The car idles rough and just gets destroyed by bumps... Thinking I need new struts but honestly tired of dumping money into this car.
Control arms
Ball joints
Tie rods
Sway bar links
Front end alignment
tires balanced
New tires
