andesmint
Feel free to make any offer on these parts! I'd rather they sell than sit on the shelf!
The switches are in varying condition, some with the image perfect and some have worn off completely. However they have all been tested and work perfectly. If you are replacing a bad switch with one of these and your switch cover is in better condition you can simply pop of the switch covers and swap them.
rear passenger or driver side switches -$8 shipped
Front passenger switches - $15 shipped
Drivers switches (without plastic bezzel) - $20 shipped
Headlight switches - $20
Mirror adjustment switch - $10 shipped
Fog light switches - $8 shipped
Digital climate control unit - $35 shipped
Non digital DIC from a 2000 - $15 shipped
I also have a set of 04+ Gauge Cluster needles, which if you are careful, can be swapped into a 97-03 gauge cluster. They look much better IMO. $15 shipped.
I also have an L36 top end with only 65K miles for sale. I'm not sure what these part are worth... and I also know shipping might suck... I'm just going to post the price I think they should be worth without shipping but feel free to make an offer. This means the buyer will be responsible for shipping fees on the items listed below!
LIM - $25. If you want I can plug the coolant ports for you for an additional 20 buck.
EGR valve with brand new gaskets - $15
UIM - $25 This only has 10k miles on it. The plenum should still be good. It also has a brand new felpro TB gasket on it cuz I had an extra laying around
Fuel rail with injectors - $15
Cylinder heads - $25 each.. These haven't been pressure tested or magnufluxed... but they did work great and my car ran perfect with them so i'd say they are good. Ill run them through a parts washer and clean them up if someone wants them
Valve covers -$15 for the pair. front VC is painted silver. ill clean them up before shipping as well.
Also i have a few random gaskets and a set of plastic coolant elbows... all brand new. ill throw them in for free if you want them and buy any of the stuff listed above
P.S. If you are looking for a common part I may be able to get it for you from a local yard. PM me for quickest response
Parts are located in Minot, ND
