Looking for some help with this beast
tomtom123
So some background.
It's a 1999 GTP with a replacement L67 out of a 2004 Impala SS. The fuel rail that came on it has the circle thing I will post a picture of it circled in blue. The reason I circle that piece in blue is because there is a ticking noise coming from it? Curious as to why it could be ticking?
The engine was regasketed from bottom up and I put a Comp Cam 76-802-9 cam in it with supporting mods including headers. And an MPS with 3.4" pulley.
Got it tuned by a guy relatively local to me. More local to me than anyone else =P
Stock injectors and new stock fuel pump.
The car idles funny, like it can't decide where to properly set the idle rpm's. Idle fuel pressure is 70psi at the fuel rail and it holds that steady. In idle LTFT's are up to +10
The car drives pretty normal, LTFT's go to -22 so I believe it's running quite rich now since my gas mileage used to be about 29 highway on 93 octane but is now about 22 to 22.7 highway on 93 octane =/
Before my recent tune, the car would see up to 7* of knock which was on both the 3.4 and 3.2" pulley. So the knock seems to me to not be boost related. But now I don't really see knock until after 60mph ish.
It seems the injectors run static at around 5500rpm's and then I start knocking slightly. Now, the log that was taken showed that when the injectors hit 18ms which was at around 5.5k rpms, the knock started rising, and at the same time the LTFT's were -12.5. So the car is trying to open the injectors 100%, but pull 12.5% fuel at the same time? Shouldn't it lower the pulse width if it wants to cut back on the fueling slightly?
So it seems the car is commanding more fuel (opening injectors more), then realizing it's running rich it tries to pull fuel (-12.5 LTFT), and it's trying to do both at the same time and is fighting itself? Unless I have this wrong.
MAF is about 10k miles old and has been cleaned in that time once to make sure it wasn't the issue/part of the issue.
Looking for some thoughts/ideas of what the problem could be. And no vacuum leaks, Seafoam test passed, no smoke.
Did you look up what stock fuel pressure with stock injectors is supposed to be at idle?
70 psi seems high to me.
The fuel rail with the circle was an update, like a small resevoir to help keep rail pressure more constant if I recall correctly.
That fuel rail is from like a 97 model year, I don't know exactly what it does but it just holds more fuel there and likely does something to fuel pressure.
70 psi of fuel pressure sounds really high also. Not sure if rail related, swap your 99 fuel rail on and see if anything changes.
See what the injector duty cycle is, injector ms doesnt always mean they are running static. If you are still only at 75-85% duty cycle, you are not running static with it at 18ms.
And seeing -22 LTFT while driving isnt right, it should not be trying to always take away that much fuel.
Well I heard 70 was normal. But I also heard 43 at idle was ideal. So I'm not positive which one is right lol. And thats what I heard as well about it being used to help keep pressure more constant.
That rail is from like a 97? It came on a stock engine straight out of an 04 Impala SS Indy 500 edition. My 99 rail didn't have that extra circle piece. I'll have to get home to replace the fuel rail sometime.
And 18ms I am understanding is static on stock injectors/pump? And the log taken of me driving showed that as soon as it hit 18ms and was commanding -12.5LTFT it started running lean.
I find it weird that the car is telling the injectors to open longer (more fuel), but then see's it's rich (pulls fuel), then can't keep up with command. Like it is confused lol
How do you know it's running lean, do you have a wideband saying it's gone from 11 afr to 12 afr???
And no, just because its' at 18ms doesnt mean you are out of injector. You need to watch the duty cycle, if you are over 90-95% then you might be right on the edge. I ran 17-18ms with 80% duty cycle on 93 pump gas doing 11 AFR commanded.
Pretty sure the fuel rail with the circle was one of the changes for 01, I have an 02 that came with one stock and have seen 01-04 built l67's with them.
My friend that tuned me was watching 02 readings and showed right where the readings start saying it's running lean. But no, I don't have a wideband which I understand does make it harder to prove it's leaning out but to my understanding a wideband is not the only way to see if it's leaning out? I am not a tuner so I can't tell you exactly what he looked at to see where/when it is leaning out. But from how I understood it, right at 18ms pulse width knock started creeping up and the 02 was reading lean from how it was explained to me.
My 2000 has the pulse disk. Also has a steel tank. I think mine is a mid year production run. (?)
It sounds like your fuel pressure regulator is bad or tank return line is plugged or kinked somewhere. 70 psi is way too high. Depending on your vacuum your fuel pressure should be around 40 psi at idle.
Check that return line first. Is it possible that you mixed up the lines when you hooked them up? If you don't see a problem with the lines then swap the rail/regulator.
Injectors tick... But not that little round thing! Injector could be an issue as well as what's been mentioned above.
Well I suppose it is possible I mixed uo the return and the incoming lines. I doubt it because I had everything connected and the car would stall after 15 minutes. Found out it would run fine right at 43psi at the rail, then it would drop to 20psi all of a sudden, and then down to 10 and stall out. Replaced the pump with a new stock pump and now I have 70psi at idle. Did nothing other than the new GM stock GTP pump for my 99GTP =/
Would a bad regulator cause problems like this? I've never had a problem with the regulator going bad but if thats the problem that would be pretty easy haha.
Yeah, I wish I lived closer to people that could listen and see that I'm not crazy ;P that disk is ticking. I first thought it was a lifter by cylinder 5 but then when I listened closer a few days later I realized it sounded like the other 3 cylinders but got much louder right on that disk. Thats why I was curious what it was.
Now the car idled fine at 43psi with the bad pump, but the pump after 15 minutes would screw up and not keep pressure and the car would stall. Now it makes the same noise as it made when it was only getting about 10 - 20psi at the rail but it's doing that while receiving 70psi at the rail.
Have you used a stethoscope to locate the noise positively? Hahaha... Never heard or seen anything about one of those disks ticking... But maybe the 70psi screwed something.
Just my ear. I was going to try and use a screwdriver to try and pin point the noise but saw the time and realized I had to rush off to work real quick. I am quite confident thats where it was coming from but I will double check as soon as I get a chance, which hopefully will be today after my classes are done! Since I get out just before the sun is down today =P lol
Just take a flat head screwdriver and put it against it and putyour ear to the end of the screwdriver.
Just did this. Definitely a clicking noise in the FPR, the same noise/tone as the rest of the fuel rail. Then the disk has a lower pitch clicking noise with an added distinct metallic tinking noise. And the injectors sounded like the noise in the FPR and rest of the rail.
And it does look like I have the lines hooked up correct and not backward. Although they don't say on them which they are, the line with the metallic sheathing on it is going to the return which matches with a picture of someone's engine bay from the forums that I have.
So are you going to swap fuel rails and see if your problem continues..
Probably. Looks like the step I need to take. But it's at my house and I'm at college right now so the results won't be found out until a little later this week when I can get home for Thanksgiving.
Turkey day is two days away.. Wait till then.. Swap em.. Post results.. At this point I think your just giving yourself a headache trying to figure out why the fpr is ticking.
Actually, I just found out last night that something is ticking and was looking for some suggestions/ideas what it could be and why. And I think giving people time to think and give ideas is good to do ahead of time because now I have an idea of what to do when I get home instead of having to try and figure out in half a day's time what things to try.
But yes, I will post results as soon as I find out. And thank you everyone that offered help and ideas
