johnnydotexe
2000 Prix, 3.8L non-SC, 4T65E.
-Cruise control does not work. There is a pink wire and a brown wire above the pedals that don't appear to go anywhere. They follow the brake light switch wires(taped together) up to the main harness. When I hooked a toner up to them I was getting tone at the cruise control box so they're obviously for CC, but I can't figure out where they originally went. I don't see their other halves anywhere under the dash and the wiring from the steering column looks fine.
-Starting some time in the last few days the interior lights stopped working and I have no idea why. I haven't done anything except look at the wiring above the pedals to sort out that CC issue. INT LIGHT fuse is good. The only two fuses not present in the glovebox are for steering wheel controls and steering wheel lights, neither of which I need and both of which I put back in temporarily to be sure they're not causing the interior light issue. I can't even manually turn on the interior lights.
