HID/Ballast Problems
Blue GTP
The light on my passenger side sometimes wont turn on if i turn my lights on and off a couple of times it will then turn on but there is about a 50% chance it turns on. Is this the ballast or the bulb. And also now it wont turn on at all. So should i just buy a new bulb and ballast or just a ballast? I know it is a 55w Ballast but how do i find the right replacement or will any 55w ballast work.
Sounds like a bad ballast or a bad ground. Swap the bulbs and see if the problem follows or stays.
^^ditto^^
swap the ballast around and make sure you have bare metal grounds
What brand ballast do you have? Any ol 55watter will do.
I personally am paranoid about those things. For matched brightness and startup I replace in pairs
^^ditto^^
the kit is a DDM Kit 55W 5000k. does that help anything ha and i will try to fix the ground but does this kid usually have a ballast go out or tend to get a bad relay harness?
DDM harness fuse by the battery like to blow/melt. but that would affect both lights not one.
I dont have a problem with mine igniting, but the womens car has vvme and once in a great great while one light doesnt want to ignite.
