After replacing all 4 wheel bearings, front struts, and front lower control arms on my 98 GTP I'm having problems with my front rotors squealing and heating up big time. I did not replace the pads or the calipers during this repair session. I put in all new rotors and pads about a year and a half ago. I compressed the front caliper pistons and greased the caliper pins and the noise is still there. It is intermittent while driving. I did have a loose brake line (which I have tightened) last week and ran my fluid pretty low, but did not notice the squealing before the repairs.
One other thing that I've been wondering is my sway bar links were rusted so bad that when I replaced the front lower control arms, they broke. For now, I have a 5 or 6 inch 5/16 bolt with a deep well socket as a spacer between the sway bar and control arm bracket and one of those spongy spacers at each end of the bolt on each end of the sway bar. I do hear the sway bar popping and shifting every once in a while. I have sway bar links on order and they will be here tomorrow, but until then this squealing is driving me insane. Not sure how the sway bar links would affect the rotors, but felt I should mention just in case.
Bottom line, I'm wondering if my calipers need a rebuild or if there may be another culprit. Could I check the calipers by removing them from the rotor and pressing the brake as long as I have a block or something to prevent the piston from coming all the way out? I want to make sure they're going back in when I let off the brake. Also, the pads need to pull away from the rotors somehow when the brakes are released, right? I also want to make sure that my E-brake problems are unrelated to my front rotor problems. Any input is appreciated.
