Re: wa04compg's- 04 CompG Vogtland FE3 Pg21
Thanx man! The rear is alot softer then it was before so now I need to do some rolling of the fenders
LOL oh its alot lower then the stock 4x4 springs...ran the stock springs for a week while I was waiting for the vogtlands...yuck
Whats the wheel size and offset?
I don't have any rub with 40 offset and 8" wide (245/45/18) on 103K FE3s and SSCs.....so just wondering
AND it looks splendid now with those springs.
Didn't you buy some of those rear FE3s for 35 each from RockAuto? I vaguely remember that
Mine are still in the basement along with the fronts
Spazz he has 30 offset
Thanks man.
His chit shouldnt be softer now. I have the same damn struts, with the same numbers.
Bought the closeout ones. Hell I would take the $70 dive and spend the 225 for the right ones if the rear is fubar soft.
Yeah the rears are the ones that where on closeout and it seems like they are fe2 or something....pushing on the car rear is literally have the stiffness
I may end up putting the stock rears back on and see if its makes a difference
Car is back apart and the new struts are def not fe3 struts...worn out stock struts are stiffer then the brand new ones are
Yeah prob what I will end up doing...trying to decide if I want to order new ones or run the old ones until they are completely blown
Yeah just sucks spending the money again and there being a chance I get the same ones
Could always return them worse case scans too. Or offload your current set up or even take to a rep from RA and explain the situation.. Hell they may just refund u back for the first set.
Buy new set return old set in new set box be like you gave me the wrong thing j want a refund. Done
