    TIPS:
Transmission parts...GMR, Cartuning etc
Does the input shaft install just like a 300m / any modifications to make it work ?
This was an early GMR shaft from what I can tell, so I believe there is a little bit of machining that needs to be done to the valve body. The butt end of the shaft is a little bit longer, which I think was done to prevent excessive wear on the channel plate sleeve.
