Scottydoggs
Killa Bee
Lets recap what you have done and just check off what you have done:
-New spark plug Check (swapped with another cylinder; no change, still cyl 1 miss)
-new spark plug wire Check
-new coil pack Check ( swapped coil packs around; no change, still cyl 1 miss)
-swapped injectors Haven't done this yet
-check signal to said injector Haven't done this yet
-check ICM Check
-check valves Check
-check rockers Check
-check pushrods Check
-check lifters Check ( visually checked, but who knows if its actually pumping up)
Is it remotely possible the cam was damaged from the missing spacer?
Ill swap the injector. Then ill pull the vc and see what going on, not that ill think ill be able to really see anything. After that I suppose ill swap the lifter out for a new one.
