97AutoXVette
I am aware of the possible issues with running a VC breather and the vacuum leaks. I have experienced this myself on some previous builds (not on GTPs though)...
I am wondering if some of you have used a breather instead of modifying your setup with Full Stack Intercoolers? If so, what did you do to the tune (or anything else) to help combat the vacuum leak symptoms? Any other adverse effects?
I am under the impression that the vacuum leaks really only affect the car during idle and sub-boost conditions. Under boost, the vacuum leak should essentially go away as the crankcase is under positive pressure right? so the issues would likely go away completely under boost..
Open to thoughts and suggestions :th_thumb-up:
