Run 103's, 104's, or TR6.......all will work with your application
Pretty sure my old was was running 103's
I am running 104s and seem to be working well. E85 should allow a bit hotter spark due to it's KR fighting abilities.
Welcome to E85 man!!!!
Basically, I would perssonally start out with the hotter plugs. If I saw a little bit of knock I would try and have it tuned out. If that doesn't work, then try the cooler plugs.
So 104's being 2 ranges colder, might be fine. If you pulley down and start seeing a tiny bit of knock you can't tune out, you may want to try the 103's
