Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The site migration is complete! Hopefully everything transferred properly from the multiple decades old software we were using before. If you notice any issues please let me know, thanks! Also, I'm still working on things like chatbox, etc so hopefully those will be working in the next week or two.
The check engine light will come on and you might lose fuel mileage if the computer keeps thinking the cat isnt working good enough, and of course it gone so it might.
Ok with a clogged cat it will get bad gas mileage also?,it's getting roughly 20 now,I thought without a cat the car will breathe better and improve,how loud will it be without it on?
If the cat is clogged that can also cause bad gas milage. W/o cat is a very minimal noise increase. If you remove the resonator you will get lots of nasty rasp and it will sound bad. Remove the cat, leave the resonator.
The only problem is that if you delete the cat without deleting that second sensor on your computer, you could throw a code because it's an o2 sensor that sits right after.. It may also effect your fuel mixture.
How do I delete the sensor,I thought I only seen 1 which was at the firewall,don't they make something to plug in it to make the computer think it's there
Thought those 02 sims didn't work on 01+ because the car would be stuck in cat diagnostic mode and burn a crap load of a gas and whack out your fuel trims.
