What did you do to your Car today?
Status
Not open for further replies.
My GTP has an issue with IACs. Twice my IAC has died and I had a SES for a TPS. If this cheap BWD sensor goes out again I will buy an AC delco.
I would, that's annoying to have happen all the time, ac delco should last since originals always last.
Does your gtp have a shift kit yet?
The impala shifts great now, but the input clutch problem showed itself again, I'm assuming the new clean fluid is flowing faster creating more of a leak at the seal. Its going to get the Lucas treatment. I'm going to start at adding half the bottle.
And right after I serviced the trans, the abs/traction control light started coming on intermittently when driving. Guess I caused the wheel bearing to fail from changing the trans fluid.
Looks like next weekend I'll be repinning a transmission harness for a guy, in exchange for everything needed for GXP brakes and GXP struts. Anyone know if the GXP brakes clear 17 inch Mustang rims?
They will but it will be close. I don't know about the fronts though. Rears will be fine
Put $56 into the tank and created a temporary fix for the bushings in the top of the driver side door hinge until I can order new bushings. Next step is to pick up a new trunk hold-down relay/motor and a new dimmer switch for the dash lights.
RALM
My car had WBRS (warped brake rotor syndrome) on the front rotors. I installed new rotors and ceramic pads today from Raybesto and they work great so far.
Bought a new toy today.
Status
