GT in Kennesaw
Vogland springs claim a drop of 1.3" over stock and while there may be some drop from "new" stock springs, my own experience was a zero (0") change in ride height. To be fair, my Grand Prix had 202,000 miles and there's a good chance that the original springs may have provided an inch of drop. I have no way to tell as my measurements were taken at 202,00 miles, not 0 miles. Other changes included new KYB AGX struts, new strut mounts, bearings and retainers, spring insulators, bellows, bump stops, anti-pogo washers and everything else related to the suspension. Everything. The list: rack and pinion assembly, inner and outer tie rod ends, front and rear lower control arm bushings, lower ball joints, CV axle assemblies, wheel hub/bearing assemblies (front only), sway bar bushings and end links (front), engine cradle bushings, lateral arms/bushings and BMR trailing arms (replacing the GMPP trailing arms that I had put on several years ago). New tires too. I did not replace the GMPP rear bushings and end links as they seemed to be in good shape. I also replaced the engine and transmission mounts and the upper torque arm bushings (poly from ZZ Performance). I'll include a few photos, starting with the before and after of the car.
Before:
After:
See, no change.
The rest are just a few shots I took during the process of changing out everything. All these steps have been spelled out in other strings and my experience wasn't different from those.
I mostly used MOOG parts, including the lower control arm bushings. I didn't buy the arms complete but decided to use upgraded parts which required the labor of swapping out the bushings and ball joint on the original arms. The ball joint removal is by far the hardest and if one doesn't have a 4" grinder, you will never get a better excuse to buy one. Having a 20 ton press also comes in very handy.
The pictures ( no particular order)
Stock, GMPP and BMR trailing arms. Any questions?
If anyone wants to see anything in particular, let me know and I'll add them.
Before:
After:
See, no change.
