Comparison Of ZZP Plog and Speed Daddy Headers
Yeah after measuring everything it doesn't seem like it would be much of a hp difference and I won't have to deal with the leaks and or issues that I have had with the headers...then if I actually do go turbo will be alot faster swap
vette, if you decide not to switch I'll buy your headers :-)
or if you do.. I might buy your plog... I still cant decide. Bonnies don't have the restictive downpipe/ubend so idk if i even need a downpipe..
I'll let you know sometime this weekend bud. They come in the mail on Friday, and I am starting to wonder if I should take the time/effort to take off my whole setup as it sits just to put on these headers that may not gain me much. I will shoot you a PM Friday/Saturday time frame and let you know man!
If I could do it all over again I would have kept my plog and 3in dp honestly. I have had some issues even still nearly 6 months later after my header install, mainly exhaust leaks and this nagging front o2 sensor issue.
Yesh I'm in it about 2 years and from the get go my crossover never fit so always leaked a little at the front connection...I changed it to a v band connection last weekend and now the rear slip fit is leaking...my o2 has always hit from time to time and now all the welds are rusting...so since I didn't find a huge difference in primaries I'm swapping back
Sounds good!
Installed plog+dp and the power band is def more down low compared to the headers...did not switch the tune and I am getting no kr going to do some tuning push out the timing
Yeah it is prob me but after messing with those headers enough times I moved on...plus if I go turbo in the future this makes it faster to switch over
When I first installed my SD headers, I had leaks... I used the clamps that came with the kit. Threw those in the trash, bought the EZ seal band clamps, no more issues.
I had speed daddy set. Couldn't get to go on engine on the engine stand. Need the engine in the car so that I could pry harder.
Never installed.
I had ez clamps from day 1 crossover just never fit right...replaced slip fit in front with v band then rear slip fit started leaking...so I moved on
