    TIPS:
2nd $5 Parts Thread!
Status
Not open for further replies.
HighOctaneRacing
When The Snow Is Gone, The Remaining Parts Will Be Trashed and Scrapped!
Parts are stock. Some are OE and some are Aftermarket. They are from a 1997 Pontiac Grand Prix 3.8 N/A
BUYERS ARE RESPONSIBLE FOR SHIPPING AND PAYPAL FEES (3%). I will also accept checks and money orders, however, shipping will be delayed until check(s) clear. All Sales Final and No Warranty(s). Everything must go!
Listed below are the last parts I have and they are $5 each!
OE Rear Sway Bars 17mm
OE Coolant Reservoir (99+ Style)
OE Washer Fluid Resevoir w/o Pump (97 Style)
OE Crossover with header wrap
FREE Parts (Buyer Still Pays Shipping)
OE Rear Crossmember
PICTURES BELOW!
Parts will be shipped from Palmer, MA. PM me if you have any questions
OE Radiator Fans w/ Shrouds & Motors
Was $50/Pair. Then $20. Now $10! SOLD!
IIRC these only work with the 97-98 years.
Duralast Gold Rear Brake Pads DG698
$10. SOLD!
I warrantied these brake pads to sell brand new ones.
Duralast Gold Plug Wires D801153
$5. SOLD!!!
I warrantied these plug wires to sell brand new ones.
Was $15 each. Then $10. NOW $5!
The bars have some surface rust where the bushings go.
OE Headlight Harness w/ Bulbs
$20/Pair SOLD!!!!!
Dorman (2) 42539 Front & Left Wiper Arms
No Longer For Sale
Wiper arms were on the car from April 2013 to July 2013. Part number is the same for both sides.
Was $25. NOW $5!
A little dirty but might be able to jet wash before sale at no extra charge
Was $10. NOW $5!
Black Decklid w/ Spoiler
No Longer For Sale
Never got to re-paint and install. Has some scratches (nothing deep) and no rust. No key hole.
RF Black Fender.
No Longer For Sale
OE Paint but has some scratches (nothing deep) and has some rust where it bolts to the rocker panels.
LF Flat Black Fender
No Longer For Sale
Sprayed it with flat black paint for temporary fix but never got the chance for real paint.
Has some scratches (nothing deep) and has some rust where it bolts to the rocker panels.
Series 2 3800 L36 Engine. Pick-Up Only!
Complete w/o Starter, Compressor, Power Steering Pump, Alternator, Throttle Body, Ignition Control Module and Coils. MOTOR IS NO LONGER FOR SALE!
This engine was pulled from a 96 Buick Regal with 77,229 miles in the fall of 2009 after my original motor blew with 121,707 miles on it thanks to Jacksons Auto. Before this motor was installed by me personally, I took the remanufactured heads off of my old block because they only had a little over 3k miles on them and installed them on this block with new head bolts and gaskets obviously. The valves, springs, seals and rocker arm bolts were new and I transferred the original rockers over to the heads. The rockers and pedestals were jet washed before installation. I sandblasted the lower Intake manifold and jet washed it before I put it on the block. The upper intake manifold is still OE because it was still in good shape and the EGR pipe did not burn a hole in the plenum. I also installed the newly designed Dorman EGR pipe. I put on new GM plastic elbows because at the time the aluminum Dorman ones weren’t out yet. The valve cover gaskets, grommets, thermostat and seal were replaced at the same time obviously. The fuel injector o-rings were replaced as well and the water pump was transferred from the old block. The oil filter adaptor was removed for easier access but will be sold with the motor. The crossover pipe has header wrap on it to help lower temps around the throttle body. The vehicle was parted out with 152,943 miles on it.
The motor has 108,465 miles on it and ran strong.
I’m willing to part out several parts of the engine for shipping.
Throttle Body w/ IAC & TPS without MAF!
Was $45. NOW $10! SOLD!
Alternator $20! SOLD!
Coil Packs and Bracket $30. NOW $15! SOLD!
Crossover with header wrap $25. NOW $5!
This is a list of the products with part numbers that are installed on the motor.
Fel-Pro Head Gasket Set - FPG HS9917PT3 RockAuto
Fel-Pro Intake Manifold Gasket Set - FPG MS98014T RockAuto
Fel-Pro Cylinder Head Bolt Set - FPG ES74033 RockAuto
GM Rocker Arm Bolts - ?Don’t remember part number? Bertera Chevy
GM Plastic Coolant Elbows - ?Don’t remember part number? Bertera Chevy
AC Delco Spark Plugs Iridium - 41-101 NAPA
Duralast Water Pump - BWP-9016 Autozone
Remanufactured Heads - Liberty Engine Worcester, MA
Other things put on over time
Delphi Mass Airflow - AF10125 NAPA – Will be sold separately from the throttle body
Echlin Throttle Position Sensor - CRB 219184 NAPA
Echlin Idle Air Control Valve - CRB 219203 NAPA
ToughOne Alternator Remanufactured - 105 Amps - P8200-11 Advanced Auto
Duralast MAP Sensor - SU1078 - Autozone
NAPA Power Premium Plus Starter - RAY 246 5116
$20! SOLD!!!
This starter is not listed for Grand Prix’s but the motor I put in my 97 Grand Prix was from a 96 Buick Regal so I bought a Regal starter and it worked. It was cheaper too lol but it is bigger than a GP starter and a little heavier.
OE Rear Crossmember
FREE
Re: Parted Out My Car... 2nd Thread!
I'm interested in the decklid/spoiler..have to get a truck/van to come pick up, you're about 2 hrs away from me. im in ny.
Is the 97 washer reservoir the same as the 99 if so I'll take it
Did you sell the whole ICM/Coil pack setup, or do you have the packs still?
Status
