I have a 2004 GP GT2 where would be the best place to order drill and slotted rotor all around for my car
I got a set off of eBay for my 98. They work fine. Stop fine. No warping. I know a lot of people look down on them because they are made in China, but, most off the shelf OEM type rotors are made in the same factories with the same materials/machines. I see nothing wrong with them.
The best drilled rotors are the ones that aren't drilled.
I'm sure you're aware that the holes are negative for performance.
I have to completely disagree... If they were soo bad for performance then they wouldnt come stock on the REALLY high dollar cars. The key is to find ones that have been cast with the holes in them and not cast then drilled.
I run R1 Concepts and I love them. I have put about 40-50k on them and have ZERO cracking and I use my brakes hard sometimes.
I run Carbon metallic pads with the R1 concepts drilled and slotted rotors. And once they are warm it is a MUCH better stop then stock.
Less surface is offset by the fact that you get less brake fade and better heat dispersion.
That my friend is common sense. While there is less contact area there is in fact MORE surface area and THAT helps with heat distribution.
The holes in the rotor will act as a heat sink too. The more surface area you have the more cooling effect it has do to more contact with the cooler air. Same principle any heat sink works off. I will concede that it does take away from contact surface, that effect is offset by the cooler temps and less fade.
