Repair on rear door power window for a 2004 GTP
p coico
So, I put my pw down the other day and heard a snap.... go to put it up and the window only went up part way, about 3/4 the way,
and will go no higher ...... any guess on what the problem is and what
I need to do to fix it .... Thanks...:cool:
I would assume you need a new regulator, then you pop the door panel. Swap it out and put the panel back on.
Thanks billboost37....
Is it a part I can get at Autozone or most local parts stores .... ?
Any pointers on the removal / install process...... I have not done one of these before.....
