    TIPS:
Parting out 2002 GTP, Taking deep discount
iefalcon
All stock parts except specified below, pictures as requested. All the OEM parts has 120,000 miles in them and they lived up well to their miles and are in As Is condition. Items located in Memphis, TN. Carry out Cash, delivery plus shipping charge(paypal gift).
attachment.php
AcDelco drive belt and SC belt(2yrs old), $15($10). http://i1284.photobucket.com/albums/a571/iefalcon/DSCbelt_zps15944cb3.jpg
Throttle body, $20.(Sold)
zzp TB spacer, $20.(Sold)
CV Axles(NEW Cardone Select Part# 661255, 661256), 80 shipped.
Alternator, $30($20).
Fuel rail with the fuel pressure regulator, $30.Sold
Fuel injector set of 6 w/ clips, $30.Sold
Injector O-Ring Seals(16 New thick ones from the AcDelco 217-1427, fit supercharged Injectors), .5/piece.
L36 fuel line from fuel filter to engine(elbow leaking @130,000 miles), $20.
EGR Valve, $15.Sold
EGR Valve(100,000 miles), 20.
Idle air control valve(100,000 miles), 10.
MAF Sensor, $30. Sold
License filler plate, $5. http://i1284.photobucket.com/albums/a571/iefalcon/LPFiller_zps69e426b8.jpg, Sold
Engine Cover, $10($5). http://i1284.photobucket.com/albums/a571/iefalcon/SightShield_zps90a0ec49.jpg
Air duct w/o sensor, $3.
Fog lights with bulbs, $15/piece. http://i1284.photobucket.com/albums/a571/iefalcon/foglight_zps6719efdb.jpg, Sold
OnStar back view mirror with temp and compass(one with about 60,000 miles), $40.
OnStar back view mirror with temp and compass(another one), $20. (Sold)
GMPP Heavy Duty Rear Sway Bar w/insulators (brand new, never get installed), $40.(Sold)
Heavy Duty Front Sway Bar w/insulator and end links(brand new, never get installed), (Sold 50 shipped)
Strut Tower Brace, $10. Sold http://i1284.photobucket.com/albums/a571/iefalcon/STB_zps5c9f6b40.jpg, Sold
Diagonal Braces(2), $15($10).
ACDelco Hose radiator to water pump(brand new backup), $10.
SuperCharger Oil, $5. Sold
SuperCharger Oil(about half the bottle), $3.
PCV valve Cover Gasket(brand new OEM of 4), $5($2)/piece.
Tail light(passenger side), $30.(Sold)
Tail light(driver side), $20.(Sold)
Tail Light(Passenger side), $5.
Cruise Control Module w/ cable(100,000 miles), $60($40).
Radiator Cooling Fan Assembly, $40($20). http://i1284.photobucket.com/albums/a571/iefalcon/RadFan2_zpse118b7cd.jpg
Radiator w/ Cap, $50.(Sold)
SuperCharger with the Plenum, boost control solenoid, bypass valves and bolts, $100($80).
SuperCharger Drive Belt tensioner w/bolts, $25.Sold
SuperCharger Drive Belt Idler Pulley w/ Bracket, $25.Sold
Generator bracket w/bolts, $25($15).
Engine right bracket w/bolts, 20. http://i1284.photobucket.com/albums/a571/iefalcon/EngineBracket_zpsfzckmyxi.jpg
EVAP Purge solenoid, $10.(Sold)
MAP Sensor, $10.(Sold)
Lower Intake Manifold, $70($50).
Fuel Pump and sender Assembly(Delco made in Singapore), $50($30).
Trunk trim Mat, $10. Sold
Exhaust Manifold w/ shield front, $10. http://i1284.photobucket.com/albums/a571/iefalcon/exhaustLeft_zps7ad959f0.jpg
Exhaust Manifold w/ shield and O2 Sensor back, $20. http://i1284.photobucket.com/albums/a571/iefalcon/exhmao_zpsgnkt1ar2.jpg
Thermostat Housing w/ inlet hose, $10($5).
EGR Outlet Pipe, $10.
Air Box complete 3 pieces, $15. http://i1284.photobucket.com/albums/a571/iefalcon/airbox2_zps55dc85cf.jpg
http://i1284.photobucket.com/albums/a571/iefalcon/airbox1_zps936bfffd.jpg
http://i1284.photobucket.com/albums/a571/iefalcon/airbox3_zps5ca53657.jpg
Cross Over Exhaust Pipe w/bolts, $15. http://i1284.photobucket.com/albums/a571/iefalcon/CrossOverPipe_zps9000f016.jpg
Valve Cover front, $10.Sold
Valve Cover back, $5.Sold
Fog Light Switch, $10. http://i1284.photobucket.com/albums/a571/iefalcon/FogLight3_zps5b125857.jpg
IPC Trim Plate, $30. http://i1284.photobucket.com/albums/a571/iefalcon/IPCTrim_zpsa824c654.jpg
Insulator Panel w/ Knee Pad - left, $5. http://i1284.photobucket.com/albums/a571/iefalcon/KneePadShield_zps83d55f05.jpg
Grille, $10/set. http://i1284.photobucket.com/albums/a571/iefalcon/Grille_zps28beae60.jpg
ACDelco Blower Motor Resistor(Less than 60,000 miles), $15
.(Sold) http://i1284.photobucket.com/albums/a571/iefalcon/resistor_zps1c6086b5.jpg
Blower Motor, $20.
Cylinder Head w/rockers, rods, springs, arm, Front, $100($70).
Cylinder Head w/rockers, rods, springs, arm, Back, $100.($70)
Back Seat Cushion, $30.
A/C Compressor Kit, $200($100). http://i1284.photobucket.com/albums/a571/iefalcon/acompressor_zps5mz4tkw9.jpg
Heater Hose inlet & outlet, $5.
Coolant Level Sensor, 10.
Engine Dog bones, $15. http://i1284.photobucket.com/albums/a571/iefalcon/Dogbones_zpsc58549cc.jpg, Sold
Windows Regulator w/ motor Assembly
front driver, 15. http://i1284.photobucket.com/albums/a571/iefalcon/RegMotorFD_zps7986bb39.jpg
front passenger, 15. http://i1284.photobucket.com/albums/a571/iefalcon/RegMotorFP_zpsa76dc51c.jpg,
Rear Driver, 5.(Cable fasterner broke, about 3inch cable at one end twisted).
http://i1284.photobucket.com/albums/a571/iefalcon/RearDriver_zps76244b59.jpg
rear passenger, $10/piece http://i1284.photobucket.com/albums/a571/iefalcon/RegMotorRD_zpsac38d4bb.jpg(Sold)
rear driver Dorman741-838 brand <1.5 yrs old, $10. http://i1284.photobucket.com/albums/a571/iefalcon/RegMotorRD_zpsac38d4bb.jpg(Sold)
http://i1284.photobucket.com/albums/a571/iefalcon/RegMotorRP_zps8505cacc.jpg
Door Trim Panels, $15/piece.
Side View Mirror Power, $30($20)/piece.
Speakers(Delco Electronics, 4ohm), $40/set of 6.
Third Brake light, $30. Sold.
Door Appliques w/ inner molding, $15($10)/piece. Take all 4, 40 shipped.
Door Window Glass Channel Reveal Molding w/ metal frame, $15/door. Take all 4, 40.
Power Steering Pump w/ pulley, 30.
A/C Heater Control Head Unit Panel, 50. http://i1284.photobucket.com/albums/a571/iefalcon/ACntrlPnlHead_zps639ef2d9.jpg
Master Cylinder w/ reservoir w/o cap, 25. http://i1284.photobucket.com/albums/a571/iefalcon/brakecyl_zps6nraplzf.jpg
ABS Hydraulic Unit w/ EBCM, 200. http://i1284.photobucket.com/albums/a571/iefalcon/brakeHydraulicUnit_zpsxi0t787y.jpg
Starter, 20. http://i1284.photobucket.com/albums/a571/iefalcon/starter_zps4hyyiqhi.jpg
Ignition Switch(60,000 miles) w/ Lock cylinder shift interlock solenoid, 35.
http://i1284.photobucket.com/albums/a571/iefalcon/IgSwitch_zps5c496c62.jpg
Oil Level Sensor, 5.
Coolant Temperature Sensor, 5.
HVAC Module(the entire assembly under behind the dash panel), 120. http://i1284.photobucket.com/albums/a571/iefalcon/ACUnit_zpsx3y3ewiv.jpg
PCM, 50. Picture link: http://i1284.photobucket.com/albums/a571/iefalcon/pcm_zps357ddd85.jpg
BCM, 40. http://i1284.photobucket.com/albums/a571/iefalcon/BCM_zps45e9d3d3.jpg
Center Console Storage Compartment Insert, 10. http://i1284.photobucket.com/albums/a571/iefalcon/pocket_zps2ff8bf0e.jpg
HeadLight Assembly(driver side), 20. http://i1284.photobucket.com/albums/a571/iefalcon/headlights_zps7f46f5d6.jpg
Door Button Switches, Front Driver, 20(Sold); Front Passenger, 15; Rear Driver, 7; Rear Passenger, 7.
http://i1284.photobucket.com/albums/a571/iefalcon/DSwitch_zps4212d8c9.jpg
Steering Wheel Button Switches, 15/set.(Sold) http://i1284.photobucket.com/albums/a571/iefalcon/strSwitches_zps65ac5ad1.jpg
Headlight/Dimmer Control Switch, 25. http://i1284.photobucket.com/albums/a571/iefalcon/LSwitch_zpse720035c.jpg
Steering Column Cover(Upper and lower), 10. http://i1284.photobucket.com/albums/a571/iefalcon/strCover_zpsf265ded0.jpg
Badge door GTP Supercharged, 20. http://i1284.photobucket.com/albums/a571/iefalcon/badge_zps76ac69ec.jpg
Coolant Overflow tank, 5.
Ignition Coil Pack, 30. http://i1284.photobucket.com/albums/a571/iefalcon/coilpack_zpsmpkxustg.jpg
Various inside plastic molding trim parts.
Anything else, let me know to see.
"mat" for the compartment under the fog light switch GM part # 10267562(Sold)
Drive belt and supercharger belt.$15
Throttle Body. $20
Throttle Body Spacer ZZP w/o gaskets, $20.
Alternator, $25
EGR Valve with intact gasket, $15.
License Plate filler, $5
attachment.php
Engine Cover, $15.
Tail Light Assembly Right, $35(used from the yard sale)
Fog Lights, 30/pair.
GMPP front sway bar w/ 2 cushions and 2 endlinks( been lay around for years, little rust on endlink nuts)
Re: Parting out 2002 GTP
Fog Light switch $15 shipped.
attachment.php
the two steering wheel control assemblies are in excellent shape, $15/piece shipped .
the STB is one from GMPP handling upgrade kit. It's still pretty new except the scratches from shipping.
