Too many Damn problems
The main reason I know that is because I have an 01 and it didn't have a cat when I got it.
Sent from A Galaxy Far Far Away........
But thats only if the rear 02 is faulty or unplugged right, if you just dont have a cat it would just throw the code correct? No bad MPGs or anything.
Sent from the Milky Way
If the downstream o2 sensor is throwing a CEL, then you car is dumping fuel most likely. I could be wrong though.........
Mine was def dumping fuel not a doubt. I experimented cause I cleaned my exhaust tip. Ran with a code. Finally got it fouled and cleaned it again and still looks clean rather than black
