Other then the sheer amount of time difference is there any reason to NOT do a Full Write everytime I flash a tune?
It just seemed that on a few cars if I did a partial write the car would act completely retarded with stuff like trans settings, but with a full write everything worked fine.
It's def interesting to see what folks post. A long term DHP user that knew Charles personally etc etc told me when using a DHP there are a few things that you always do.
Always have a spare pcm with your last good tune on it
Always do a full write.
Then I see guys like DH etc saying partial is good. Just last week or the beginning of this week.. a guy said it only took him a couple min to write. Which..anyone with a DHP know.. you'll get at least a beer per write.
You have an HPT correct? DHP is a much older critter. The issue appears to be that the data lines on the 04+ are much more congested, therefore by removing the fuse you disable a few things from talking. Years back Monte guys were putting in a switch and totally bypassing the rest of the car while writing. They'd run a dedicated line with switch to go straight to the pcm only.
