ect sensor (check PIDs for temp), wiring loom below Tq links (seen 2 so far that rubbed through and killed corcuits)
What is your pcm programmed for? 200 degrees isn't hot.
you could still have an air pocket under the T stat.
let it sit and the T stat should open
Ok, your pcm has stock settings which typically have low speed fans come on at 218F and high speed at 228F.
Help me understand why you think the fans should come on at 200F? That's how I read your post. Did I miss something?
If your temperature didn't warm up to the thermostat temperature in 10 min, you would get a code for coolant not reaching temp fast enough. The only thing I have found that heats up a motor fast is air in the system and or a problem with a water pump.
Really not seeing the problem in what you have said....
Doesn't matter what the thermo is.. pcm has settings.
BTW it is Burp, burb is short for suburbs. Burp is to belch, blow gas from the mouth.
