How do you check if LIM or HG is the issue?
mil
Greetings folks,
We just purchased an older Grand Prix for next to nothing with, what we assumed at the time, a blown HG. I started browsing these forums looking for a good how-to for HG replacement when I began seeing various posts stating that chances are LIM is the issue and not the HG. So what is a good way to check and see which one is the culprit? Or should I just replace everything at once?
For the record I can't remember 100% which engine it has but im pretty certain it is the 3.1. We're going tomorrow to tow it so ill get all the specifics then.
Thanks in advance,
Adam
we need to know what engine it is really.
bubbles in the radiator after revving the engine rad cap off is one sign of a blown head gasket.
Greetings folks,
Thanks in advance,
Adam
If you have a 3.1 it is almost certainly the head gasket that has blown.
A 3.8 on the other hand, it is the LIM.
A failure of the other gasket is super-rare on either engine... I've only heard of one 3800 head gasket blown. Every Craigslist 3800-powered car I've ever seen where the seller claimed "head gasket" it was invariably the LIM gasket instead. The symptoms can be similar, though... antifreeze and oil mix and become friends. Not good.
It's the 3.1 and there's coolant in the oil so it's looking to be the head gasket. This'll be fun.
Does anyone have a parts list for this task? I know there's a HG kit out there but I'm curious what else I should do while it's torn down. I'm new to pontiacs so yeah. I was a Jeep guy until mine died.
Don't buy the head gasket kit it comes with the cheep plastic intake gaskets. I'm not sure what all you will need off the top of my head.
Sent from A Galaxy Far Far Away........
