Thought about replacing the seals in the rack. The PS fluid was low, have not seen any drips yet, but my two 06's need it, this is the purpose of car, is to try something that I might not try on my drivers. I say this before I get the "Just get a reman" quotes.
Some of the questions I asked on the other thread, but I thought this one may have a different audience.
I found this thread on R&R, but nothing on replacing seals. As I said, I have two 06's that could use it, from some chatter it sounds like the experience may be the same. Here's the thread :
http://www.grandprixforums.net/04-rack-pinion-replacement-2868.html
Also another reason I think the experience would be the same, is I looked on rockauto and both kits seem to have the same part number, which leads to some questions ...
I wonder if anyone has any experience replacing seals?
TL, Would you have an exploded diagram of a 97 and 06 to compare?
I am a little confused about the parts.
This picture says "W/Magnetic Variable Assist"
More Information for ACDELCO 36348363
and this one does not say either way
More Information for DORMAN 905515
The 97 and the two 06's does not have MVA, while my 07 GXP does. So which kit is right for the 97 and 06s?
Also in the spirit of testing, I really stepped out on a limb. I bought new both wheel bearings and both tie rods ends on ebay. Both wheel bearing shipped was $60 and both tie rods shipped was $18. Again, before I get the "you get what you pay for" posting, this is the purpose of this car. I did get the bearings and the box, color, and from China reminds me of the ones I bought from O'REilly's. The only difference is there was no instructions on being careful on the torque for the axle nut. If I remember right it was 150 ft pounds. Still waiting on the tie rod ends. I would like to make a decision on resealing the rack before I replace them. Them being the wheel bearings, tie rods, and links.
Still got plenty to do, and school starts back 8/19. Next post, I may start a punch list.
Just a start, not all inclusive, and not in order ....
1. :th_thumb-up:valve cover gaskets
2. :th_thumb-up:flush, new thermostat, :th_thumb-up:clean overflow tank, and refill with antifreeze
3. replace carpet
4. :th_thumb-up:replace shifter cable
5. replace both front wheel bearings
6. replace both outer tie rods
7. replace both sides sway bar links
8. finish headliner
9. remove rear tint ( while all trim is out for carpet/headliner) Since everything is out of car, see if I can get a deal on re-tint.
10. :th_thumb-up:look at and remove side windows, if quality is good enough, may just try and match the rear as close as possible. Not sure if I want to tackle tint just yet. The sides look pretty good, I think I will just do the rear.
11. install remote start
12. Add flasher to mirror upgrade.
13. Add Pontiac projectors to the doors.
