un plug the temp sensor under the t stat in the lim
lim. lower intake manifold.
where the upper rad hose meets the engine, under that part is a sensor and a plug. unplug it.
does your a/c work?
unplugging the temp sensor will make the fans turn on asap if the relays are working.
could muck up a t stat. but dex wont keep your fans from coming on.
dont think so, if the rad is full. the low coolant sensor is dirty or broken. unplugging it turns off the light full time.
