Trying to make 400 whp! Need Help!
GTPMidknight
Mods installed on the car are:
Zzp 3 0 modular pulley
Zzp 2.5" Liquid to air intercooler
Machined gen 3 LIM
Cold air intake
Ubend delete
Voltage booster
Alternator rewire
Autolite 103s
10.5mm wires
Summit racing 40000 v coils
UPDATE:
Mods getting ready to be put in:
Stage 3 heads
42.5 injectors- Installed!
36 GPM intercooler pump from harbor freight
Intense stage 2 cam
Ls7 lifters
Pacesetter ceramic coated headers
Catback 2.5" Exhaust
ZZP 1.0 tune for 42.5 injectors and the stock maf sensor
With these new items is it possible to get into the neighborhood of 400 WHP on the m90 maybe drop the pulley to 2.8"?
I have 42# injectors on the way. I am trying to get either an xp hot cam or 1.9 rockers. I am open to any and all suggestions. Ive had serious KR problems and problems running lean I have had some minor scarring on CH 1 on the cylinder closest to the fender well on the paasenger side.
You wont reach 400 whp on a supercharger setup easy.
Not without doing a super duper tiny pulley, big intercooler and some meth or nitrous.
Go turbo for 400+ whp.
400whp at the wheels or crank.. Either way your going to need some more work probably e85, big cam and some head work and you'll be maxing out the eaton to do so...turbo in the other hand much more doable
On a real dyno (SAE corrected/dynojet) xp/full size ic/e85/headers/stage 2 heads/2.6 pulley/etc, etc, etc... made 348whp. (356 STD corrected, the wbody scene feel good correction factor)
So yeah... good luck with that :-p
Im trying to track down heads and a cam. Is it possible to piece a turbo kit together or is it more cost effective to buy one?
Is that ZZP Intercooler that sits underneath the m90 still useable with a turbo kit?
The intercooler for the m90 is water-to-air, you want to go air-to-air intercooler when you go turbo. So no it is not, best bet is to sell it to fund the turbo.
Im unfamiliar with what e 85 means sorry im a noob.
E85 is a 85% ethanol fuel, has the effect of a really high octance fuel, allows you to advance timing further and get some more power...among other things (simple explanation, it does more than that)
If you know exactly what you're doing then fabbing up your own kit will save you a bunch.
That's what I did and I still spent right around $2000 on JUST the turbo stuff.
That doesn't include injectors, tune, and fuel pump.
Also your trans will eventually break.
Many used kits pop up in the for sale section for a decent price, take a look.
More power means you put more stress on the weak link which is the transmission.
Where in VA are you? Im in Arlington...... AND im on E85 it is doable around here HOWEVER there is only ONE station that has E85 and its out on Wisconsin Ave. If your not around the DMV metro area good luck finding it ......... Ive tried!!!
Ive got 330whp/400wtq
S1X cam, E85, 60# injectors, Gen5 supercharger, headers.
Not a very long list of mods but with the trans in the car if your near by I'd like to meet up and check out your ride too. Not many Wbody guys around here.
Me personally anything that requires an expensive IC setup or a set of ported heads on a SC car is still going to be really really hard to crack 400WHP!!!
IF your hell bent on reaching 400whp turbo hands down don't ever waste your timing doing an IC or heads on SC Setup........
Ask around the forums and ask jayroca member on here what he thinks of my car........
He is currently in the process of ditching his IC setup and switching to E85!
As the previous owner of my cars said it best "The little E85 car that could changed his mind......." Quoted GMRBADASS aka Greg.
Again if your around the DMV im willing to help have HPtuner and pulley puller also just a FYI
Edit: 330whp/400wtq is enough to piss of a few rich dudes around here just sayin........ Not to mention the setup in my car would be pretty cheap to duplicate. Stock heads Stock bottom end, NO IC!
Im in virginia beach. Would definitely like to get together in the near future. I got nobody to talk motors and BS with! Pm me your number Ill send mine in return.
Vet, got a dyno sheet for that 330whp with just e85 and an s1x?
Sure do let me find it its from when greg had the car......
Made jayroca want to ditch his IC setup on his XP cam car so take it for whats its worth.... Me personally I think he IC on a Supercharged setup is a pain in the ass
Zex kit chillin in the closet..... If I can man up and spray this car before the summer is over at Maryland International Raceway. With a 75 shot id hope to crack 11s and be over the 400whp mark along with damn close 500wtq mark.
Need to get the HPtuners on and see what the duty cycle looks like on the 60#ers on E85 first.
