Downpipe bolts
jayroca
Banned
Ok guys I almost finishing up my engine swap but my downpipe bolts are holding me from putting my rear headers In could i use shorter dogbones and 3/8 ratchet socket to pull will I have enough clearance to pull the bolts off? I would like to take them from the top of the motor if necessary thanks!!
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Bill im at work right now when I get hm i'll take a pic im tryna put my rear header in and take out the stock rear manifold but I have to take 2 downpipe bolts to the rear manifold that sounds better?
Oh..ok.
If you go underneath with a swivel and extensions..you should be able to get them.
Otherwise..you could sawzall the pipe as high as possible But getting them from the top..is a huge pain.
Oh..ok.
Yeah i dig could I use shorter dogbone mounts for more clearance to break the bolts loose? I have some laying around
