Scottydoggs
Killa Bee
as long as your in there why not? there maybe better brands, id wait for other to add their two cents about brands.
Yeah, I haven't researched that too much yet. I just hopped on eBay from my phone and grabbed the first link I found for an example. This morning was actually the first time I've read in to those solenoids so still some research to do but seems logical w/the Trans opened up/drained...as long as your in there why not? there maybe better brands, id wait for other to add their two cents about brands.
Triple edge performance says GM started using the hardened 4th in 2003. Are they the definitive source, I mean besides GM? Does that mean the 03 engine Trans I'm buying may have it or does that mean GM would have used it in 03 for 04 model years? Just trying to figure if I'm setting myself up for more work than I may need to...04 and up should have a upgraded 4th, but not all of them got it. 05 up was a sure bet.
they used up old stock i guess in the 04's.
Basically a "C" shaped plate, drilled in pattern of a couple of strut tower bolts w/ a rod in between...?Or just make your own out of a template![]()
That's where "basically" comes in. I know it will take a bit more but that should be the basics of the design I thoughtUh not really lol.. Check out the website and you'll see. If you have something to cut and make them with do it!
