Fuel pump resistor jumper connector? (Caspers kit)
97AutoXVette
So, I am in the process of installing my fuel pump hot wire kit made my Caspers. I am about to replace the stock fuel pump resistor in my 1999 GTP, when I look in the kit, and can't find the resistor jumper connector anywhere...
has as anyone else who has installed one of these come across this same issue? Maybe they forgot to include it??
please help!
thank you!
The second kit did. If you need one just call intense most likely he will send you one at no charge. They are a great bunch of guys over at intense they have always been very helpful.
Okay, they're not open again till Monday. In the meantime, can I just put a wire in the two prongs where the resistor would normally connect to?
also, another issue... The toe connectors going to the fuel pump. 1 is correct, and clips in just fine. The other is a 4-prong, stock is 3-prong... Did anyone come across this as well??
