Flexplate is trash....
Still tryna diagnose what's wrong if the flexplate wasnt cracked or broke the car would be able to be driven right guys? 3800's guru's step in vid below when I rev it the sound goes away though
http://youtu.be/mXUSY_uqj74
Sent from my SAMSUNG-SGH-I747 using Tapatalk
make another vid, take the throttle and hold it at 2000 to 2500 rpm for a few seconds, then drop the throttle. let it go right back to idle.
that will be much more telling vid.
Get underneath the car to and remove the inspection cover... And shine a light up there and you should be able to see the condition of the plate and if needed have someone turn the motor over via the crank bolt while you inspect the flexplate.
