Pay close attention to transmission temps not looking for it to go past 200 degrees. Also have a transmission service done on the car. As you can imagine on the GXP models the transmission is the weakest link.
If you plan to keep the car long term it is recommended to add an auxiliary transmission cooler.
Also those look like aftermarket head and tail lights. You will want to make sure they were properly wired and it is known that aftermarket headlights have horrible night time output.
Also keep in mind that the front tires are wider than the rears. When replacing tires most folks like to go with 245/45/18 size tires all around so they may rotate them.
Also has an aftermarket cold air intake so the previous owner might not have been gentle since he/she was looking for more performance. Check transmission fluid for color and smell. You want it to be bright red and have no burnt smell. If it is brown and has a burn smell the trans might not be in the best of shape.
Go do the GXP commandments.
Thou shall install a trans cooler
Thou shall install a shift kit
Thou shall get a tune.
The V8 engine comes with "Displacement on Demand" ( later called Active Fuel Management) which puts the engine into 4 cyl mode when cruising. This makes the engine use a little oil. It's not a deal breaker, just be aware that it will use some. Make sure the rims say "Alcoa". Always wanted those on my GT. Nice car.
You want to get DoD tuned out because its not good on the TC iirc.
Sent from my Galaxy Tab 3 8.0
Side note...even if you have the same size tires the rims them selves are different widths. Its just the nature of how the car was built.
Like everyone else has already said do not go cheap on maintnence get the trans work done...don't wait especially before summer. Those stupid high trans temps coupled with dod and stock transmission settings will eat it alive very quickly..
Have fun with the car and feel free to reach out for help
Interesting, why were they built with different widths?
When you guys say transmission service, do you mean just a routine flush or are you referring to something more invasive?
Also, I will try to search around and look into the trans coolers...Got an estimate of what one would run (installed)?
The wider rims in the front are GM's answer to tourque steer. Because it is a FWD V8, it will tend to pull to the side on heavy acceleration and traction loss. The idea of the wider rims in front is that the rear should lose traction first, reducing torque steer. I'm don't really have an answer on how effective it really is.
---this..tourqe steer is a factor under acceleration while having the wheel turned in a given cornering situationIt's less about torque steer and more about cornering.
