You use the OE case so you can mount the flasher in the stock location under the dash.When using the new Tridon flasher with the old case can I just use a hot glue gun?
I installed the ep28 flasher while waiting for my Leds to come in and everything was fine, installed the signals last night on the front only and still have hyperflash. Any suggestions?
Very strange. When I did mine I had Spyder LED tails (which have built in load resistors) and LED fronts and all worked fine.99 gtp.....Could it be something to do with not having leds all around?
This is for the 97-03 GP's. 04+ does the flashing through the BCM. Not sure if you can tweak it at all.I have been looking yet found no luck to how to do this to a 2004 grand prix.. I can't find the flasher and multiple websites say different things.. Its built in the hazard button, its not modifiable, its under the dash, someone halp!
Did you hear that? that was the sound of my heart breaking...This is for the 97-03 GP's. 04+ does the flashing through the BCM. Not sure if you can tweak it at all.
