He may already have some?
If your getting/making the stattama intake, aftermarket fuel rails might be something worthwhile
What is a bap? Boost a pump?
I'll be running a racetronixs pump and planned on getting the upgraded harness. Is that what you ment or did you think i was still going to use a stock pump?
Jp it is.
Blowfish...it's only a cupple months max!
I heard he is suppoed to be comming out with a better 3rd clutch setup here soon because of some of the wot 2-3 shift problems some people have with high boost levels.
I already posted in the post about the injectors.![]()
Would rather spend 800 dollars more (on new Precision intercooler and custom piping) and have everything new then use a turbo that has had who know's how many passes pushing 22lbs of boost. But thats just me.
2 dyno's and 3 track passes with over 20 psi
Just to confirm this fuel pump rewire from zzp is the same as a bap correct? Or no?
No, they are not the same.
The fuel pump rewire will hook up to the BAP. Both are needed. Tho i might skip the ZZP rewire. The caspers fuel pump hotwire/rewire is alot higher quality rewire and already has the right connection to hook up to a MSD boost-a-pump.
