BlownGP's 2006 Build Thread
This car is a pain in the azz finally got the coolant ebows changed that was one heII of an ordeal then i go to install the aux hook up and it sounds like sh!t so im gona try and fix that tommorrow also gona fix the terrible exhaust leak then i need to get front and rear bumper covers
sent from my outdated S3
Fvckers both broke off inside on both ends it wasnt tgat bad just a bigger pain than i expected
Did you get the same one as me. Maybe I can help
I took my 12 volt power source from the climate control the brown wire doesn't go anywhere. Everything else is plug and play and make sure your like RCA to aux cable is plugged into the side closest to the harness the other side will make it just come through the tweeters and make it sound like **** I figured that out while I was testing it with my dash apart
I shoulda made a video no one makes a video for it
thanks man my rca to aux cable was junk went and bought a new one it works perfect now easy install besides the hiccup
Need to get some pipe to replace the resonator its straight piped right now haha im glad it isnt my DD shes loud!
